Edge keeps running in the Background
2023-10-23T13:57:28+00:00
Hi All,
I know ... this is old and usually easy ... turn off "Startup Boost" and "Continue running background apps ..."
I have those off and it always worked they way it supposed to.
All of a sudden Edge keeps running.
Indication for still running comes from Ccleaner, which removes all trackers. All of a sudden I get the message:
(paraphrased) Ccleaner can't clean because Edge is still running ... needs to be forced shut down"
In Task manager I also still see 11 Edge processes going even though Edge is shut off.
Again ... "Startup Boost" and "Background Apps ..." are unchecked in settings.
Any suggestions?
I repaired Edge already and nothing changed. Its updated.
PS: I checked in another machine (Win10), same Edge version ... no problems here ... all Edge processes in Task Manager disappear
when shutting Edge down.
Microsoft Edge | Other | Windows 11
    2024-03-05T06:23:36+00:00
    It's fine good if worked for everyone
    I clean installed windows 11 home removed inbuilt edge and installed edge beta. I do not have any problems now
    2024-03-05T04:54:56+00:00
    The fix worked for me too.
    I was just replied to the post from Jack A2 =
    "This workaround is 100% percent false and Is not gonna work because if you go in edge://policy tab , we get to know that it gives an error saying it is an unknown policy"
    2024-03-05T04:38:52+00:00
    DV_764 - Rosco here -
    In reference to this previously posted site:
    https://www.reddit.com/r/MicrosoftEdge/comments/1ac4ioa/a\_workaroud\_to\_prevent\_background\_running\_after/?rdt=39748 I'm not sure who's talking to who, but the 'workaround' located INSIDE that site (highlighted in blue to download) takes you to: "Elevenforum" It worked for me just by downloading and running the editor.  I'm fixed so no need for me to reply anymore.
    2024-03-05T04:14:59+00:00
    You said "Is not gonna work" but this workaround is the only one that WORKED FOR ME (and for many others too).
    This is the most important and I don't care what the policy tab says.
    2024-03-04T14:59:11+00:00
    Hi LShel42,
    don't know what to say or how far to go with describing the Win10 machine.
    In Edge I have, of course, Turbo Boost and run in Background turned off.
    Privacy on strict ...that's all there. No hacks in registry or group editor needed.
    Edge always closes as soon as I click x.
    The machine itself: all updates / separate SSD drives for only system and storage, Intel i9, 32 GB RAM, Nvidia 970 pro ... but I think al that doesn't matter. All in all ... nor special settings regarding Edge, because it never had that problem. It only started with Win11 latest updates (app. 1/2/year ago)
    With the Win11 machine - Now I use InPrivate - works great ... no background running and no gossip. However, even without InPrivate I don't have that problem of Edge not shutting down anymore. But I made the registry hacks, Windows Settings changes, uninstalled ANYTHING Ai, e.g. Copilot/ OneDrive, stopped Telemetry, anything Windows reporting, and other stuff ... no background running anymore.
    However, I still use InPrivate since one of the changes (as in one of the previous posts) requires to switch to Google in Edge Settings > Privacy > very bottom > Address bar ... don't want anything Google on my machine.
    That's all I can come up with right now - hope it helps.
