Web Select Option Gone After Recent Edge Update
2023-06-04T16:11:02+00:00
MS Edge Version: 114.0.1823.37
For some reason, I no longer have the Web Select option in the right-click context menu. I still have Web Capture, but Web Select is no longer there. Did MS remove this feature, or is it a bug?
Microsoft Edge | Other | Windows 10
    2023-11-03T15:53:13+00:00
    This worked for me. For some reason when I updated windows with the optional updates it came back for me.
    2023-11-03T16:35:38+00:00
    I've tried about half of these fixes and none has worked for me so far. I did download Firefox but I don't see the option when I right click. I use web capture web select for text that I cannot simply select, copy and paste into a document.
    2023-11-04T08:54:51+00:00
    it keeps coming and going with every update. And because you cant stop edge updating. You just have to accept what happens. Maybe the team is A / B testing. definitely seems random. 😒
    only chance that we will see web select back is to use the feedback feature and ask for web select to come back, if you dont send feedback you will never see it again.
  4. Deleted
    2023-11-06T10:18:16+00:00
    If you're missing Web Select PLEASE PLEASE PLEASE upvote the feature request here, if enough people do it might get traction:
    https://feedbackportal.microsoft.com/feedback/idea/360a6a43-3071-ee11-a81c-0022484e5453
