Other issues or features related to Microsoft Edge on Windows 10
I have Windows 10 Pro running my computer and would like to completely get rid of Edge. I don't use it and don't plan on ever using it so it's basically just a nuisance to me. Any help would be appreciated.
[Moved by moderator from Word forum]
As far as I know, it isn't possible to get rid of Edge completely. However, you can install some other web browser and set it as the system default.
Hi Wild, Welcome to the Microsoft Community. I am a Microsoft user just like you, and I hope you are well.
Please note: This is a user-to-user community forum. We are users just like you who help others. We are not employees of Microsoft.
Microsoft Edge is the web browser recommended by Microsoft and is the default web browser for Windows. Because Windows supports applications that rely on the web platform, our default web browser is an essential component of our operating system and can’t be uninstalled. To provide our users with compatibility, compliance, accessibility, and performance, we'll continue updating Microsoft Edge through the browser installer or Windows updates.
I am NOT a Microsoft Agent/Employee.
I hope this is helpful! Best Regards, Utkarsh
Yeah we know.
Its a generic bot response.
There is a way, but if you have used and saved data on Microsoft Edge, yu should get that data backed up, there is a regedit key that prevents from removing it, search it on google and you have to go there (Open Regedit as Administrator tho') and put all the carpets and search until the archive "Microsoft Edge", then find a DWORD called "NoRemove". Set it from 1 to 0. then go to Control Panel and see if the Uninstall button appears up there, and if you get to the uninstaller, it will glitch or appear a normal window (Depends on the OS, From Win 10-11), and uninstall it. Done!
To provide our users with compatibility, compliance, accessibility, and performance, we'll continue updating Microsoft Edge through the browser installer or Windows updates. I am NOT a Microsoft Agent/Employee.
Bro says “we’ll continue updating microsoft edge” and says he isnt a microsoft worker? Thats sus.
