Other issues or features related to Microsoft Edge on Windows 10
I have Windows 10 Pro running my computer and would like to completely get rid of Edge. I don't use it and don't plan on ever using it so it's basically just a nuisance to me. Any help would be appreciated.
[Moved by moderator from Word forum]
As far as I know, it isn't possible to get rid of Edge completely. However, you can install some other web browser and set it as the system default.
Hi Wild, Welcome to the Microsoft Community. I am a Microsoft user just like you, and I hope you are well.
Please note: This is a user-to-user community forum. We are users just like you who help others. We are not employees of Microsoft.
Microsoft Edge is the web browser recommended by Microsoft and is the default web browser for Windows. Because Windows supports applications that rely on the web platform, our default web browser is an essential component of our operating system and can’t be uninstalled. To provide our users with compatibility, compliance, accessibility, and performance, we'll continue updating Microsoft Edge through the browser installer or Windows updates.
I am NOT a Microsoft Agent/Employee.
I hope this is helpful! Best Regards, Utkarsh
After trying all possible ways as mentioned in many sources and nothing has helped, I have taken a layman approach, searched for edge in entire system and deleted all files (which ever the system could delete only) . Now downloaded Edge and installed. :-) It worked for me.
Ok, you can't definitely get rid of it but you can definitely disable it.
Go to Settings, then search for Control Panel*,* go to Programs*,* you'll find under Programs and features the setting> Turn Windows features on or off enter it. You just need to find Internet Explorer 11*(thats the name EDGE has deep in the system)* **** and uncheck it.
After this process you'll need to restart your pc, then theres one last thing.
Go to START and right click on Microsoft Edge> More> Open file location> Look there for the Microsoft Edge Icon and delete it.
This process wont delete this annoying browser but it will disable it and you wont see it any more.
Hope it helps.
Regards!
Microsoft Internet Explorer is deprecated and has been closed down.
Its also been removed.
