Other issues or features related to Microsoft Edge on Windows 10
I have Windows 10 Pro running my computer and would like to completely get rid of Edge. I don't use it and don't plan on ever using it so it's basically just a nuisance to me. Any help would be appreciated.
[Moved by moderator from Word forum]
As far as I know, it isn't possible to get rid of Edge completely. However, you can install some other web browser and set it as the system default.
Hi Wild, Welcome to the Microsoft Community. I am a Microsoft user just like you, and I hope you are well.
Please note: This is a user-to-user community forum. We are users just like you who help others. We are not employees of Microsoft.
Microsoft Edge is the web browser recommended by Microsoft and is the default web browser for Windows. Because Windows supports applications that rely on the web platform, our default web browser is an essential component of our operating system and can’t be uninstalled. To provide our users with compatibility, compliance, accessibility, and performance, we'll continue updating Microsoft Edge through the browser installer or Windows updates.
I am NOT a Microsoft Agent/Employee.
I hope this is helpful! Best Regards, Utkarsh
It is not recommended to completely remove Microsoft Edge from your computer as it is an integral part of the Windows 10 operating system
This is nonsense.
It's totally **** that it runs in the background and you can't disable it. I'm on the last remaining windows PC in my life and I hate that I have to use such a bloated piece of ****. It's easy to accept the fact that Mac does not allow you to disable most things in their OS because it's never fails 99.9% of the time. Windows is desperately trying to shut down a users ability to disable software that they don't want except Windows is always crashing.
How is it that my Macbook Pro with and M3Pro chip and 20 gigs of RAM completely out performs my studio PC that has 128GBs of RAM and a i9 processor? It shouldn't but add a ridiculous amount of RAM leaking unwanted software and that's what happens.
Just ****...pure ****.
I get an error when entering this command:
Remove-AppxPackage : Deployment failed with HRESULT: 0x80073CFA, Removal failed. Please contact your software vendor. (Exception from HRESULT: 0x80073CFA) error 0x80070032: AppX Deployment Remove operation on package Microsoft.MicrosoftEdgeDevToolsClient_1000.22621.1.0_neutral_neutral_8wekyb3d8bbwe from:
C:\Windows\SystemApps\Microsoft.MicrosoftEdgeDevToolsClient_8wekyb3d8bbwe failed. This app is part of Windows and
cannot be uninstalled on a per-user basis. An administrator can attempt to remove the app from the computer using Turn
Windows Features on or off. However, it may not be possible to uninstall the app.
NOTE: For additional information, look for [ActivityId] e92f44e0-648f-0008-739d-6ef28f64da01 in the Event Log or use
the command line Get-AppPackageLog -ActivityID e92f44e0-648f-0008-739d-6ef28f64da01
At line:1 char:35
I don't know what this means
