Other issues or features related to Microsoft Edge on Windows 10
I have Windows 10 Pro running my computer and would like to completely get rid of Edge. I don't use it and don't plan on ever using it so it's basically just a nuisance to me. Any help would be appreciated.
[Moved by moderator from Word forum]
As far as I know, it isn't possible to get rid of Edge completely. However, you can install some other web browser and set it as the system default.
Hi Wild, Welcome to the Microsoft Community. I am a Microsoft user just like you, and I hope you are well.
Please note: This is a user-to-user community forum. We are users just like you who help others. We are not employees of Microsoft.
Microsoft Edge is the web browser recommended by Microsoft and is the default web browser for Windows. Because Windows supports applications that rely on the web platform, our default web browser is an essential component of our operating system and can’t be uninstalled. To provide our users with compatibility, compliance, accessibility, and performance, we'll continue updating Microsoft Edge through the browser installer or Windows updates.
I am NOT a Microsoft Agent/Employee.
I hope this is helpful! Best Regards, Utkarsh
This used to work, but Microsoft figured out how many millions of people were unintalling Edge (because it's hot garbage), and they closed the back door.
Should be interesting to see if this gets deleted.
you can compleatly remove Edge from windows, it's to compicated and "this is by design." there is no reason other then the legal requierment to make it this way, they are not alowed to install their own seperat browser app in there OS, so they pretend that the browser is an intricat part of the OS, Chrome is more a Web Browser then an OS ot begine whit and MacOS is doing the same as windows.
The problem is that Edge is NOT actuly an "critical components" of the windows os as much as they pretned it is, it can be removed deleted and windows will run just fine if you do it correctly, windows will reinstall it the moment it detects what you did and usualy it's not worth the hassle.
but Edge cause problem whit other browsers and several apps break becase of how Edge will place itself in the way.
I wish Edge would be optional.
you can still do it it's just more involved and more of a hassle when it's worth
