Other issues or features related to Microsoft Edge on Windows 10
I am a Microsoft Edge user and I have recently noticed that my browser is attempting to connect to bzib.nelreports.net and deff.nelreports.net. My security software, Bitdefender, has flagged these connection attempts due to an expired certificate.
I would like to understand why these connections are being made and whether this is expected behavior for Microsoft Edge. If it is, could you please provide some context as to what bzib.nelreports.net and deff.nelreports.net is used for? If it’s not expected behavior, could anyone advise on the steps I should take to address this issue?
Note: This issue was fixed on 15 Nov 2023 by updating the site's certificates.
Explanation:
Several certificates used on subdomains of this domain expired last week. Certificate expiration has no impact on security or the end user. Basically, the browser will not be able to submit network error logging reports until the certificate is fixed. Network error logging is an HTML5 feature that helps site owners discover network connectivity issues.
Your security software simply announces "Hey, this certificate is bad", a fact that the browser already determined for itself and responds to by not connecting to the server in question.
Security software provides a redundant warning; the browser will not use connections with expired or invalid certificates.
Subdomain names are random strings of characters with no particular meaning.
The appropriate team has been informed of the certificate expiration and corrected the issue.
This issue was fixed on 11/16 by updating the certificates.
Chris carried out your suggestion and at present appears to have stopped fault showing - thanks
*.nelreports.net is a Microsoft domain. Several certificates used on the subdomains of this domain expired last week.
There is no security impact or end-user-impact of the certificate expiration -- Basically, the browser will be unable to submit Network Error Logging reports until the certificate is corrected. Network Error Logging is a HTML5 feature to allow site owners to discover network connectivity problems.
Your security software is just announcing "Hey, this certificate is bad", a fact that the browser already was determining on its own, and to which it responds by not connecting to the server in question. The security software provides a redundant warning -- the browser will not use connections with expired or invalid certificates.
The subdomain names are random strings of characters with no particular meaning.
The relevant team has been notified about the certificate expiration and will correct the issue.
Thanks Eric Lawrence (ericlaw)!
Merci beaucoup, ça commençait à m'inquiéter cette histoire.
