How to Turn Off Ad Blocker in Edge
2023-10-15T22:01:10+00:00
I' need to turn off ad blocker in edge.
I've spent the last half hour trying to find this setting.
Cal anyone tell me how to turn off ad blocker??
James
Microsoft Edge | Browser extensions | Windows 11
2023-12-03T02:19:24+00:00
Hi
Welcome to Microsoft community.
To turn off the ad blocker in Microsoft Edge, you need to disable the tracking prevention feature. Here's how:
  1. Open Microsoft Edge.
  2. Click on the three horizontal dots in the upper-right corner of the browser window to open the menu.
  3. Click on "Settings".
  4. On the left side of the Settings page, click on "Privacy, search, and services".
  5. Scroll down until you see a section titled "Tracking prevention".
  6. You'll see three options: Basic, Balanced and Strict. If you want to turn off most ad blocking features without completely disabling tracking prevention, select "Basic". To completely disable it, toggle off "Use Tracking Prevention".
Please note that if you have installed any third-party extensions like AdBlock or uBlock Origin in Edge browser, these steps won't disable those extensions.
To disable third-party ad-blocking extensions:
  1. Click on three horizontal dots at top right corner of Edge browser.
  2. Go to Extensions.
  3. From here you can either toggle off your ad-blocker extension or click 'Remove' button to remove it entirely.
Please feel free to let me know if you have any further updates, thanks.
Best regards
Derrick Qian | Microsoft Community Support Specialist
I have removed my adblock extension and disabled tracking prevention both to no avail. Both Tubi and YouTube continue to say disable my adblock.
46 additional answers
    2024-06-04T13:06:10+00:00
    P.S. Also, if you did not add the Extensions button to the toolbar, you can add it in these steps:
    1. Click on Settings and more (...) in the toolbar.
    2. Click on Settings in the menu.
    3. Go to Appearance < Customize toolbar.
    4. Under "Select which buttons to show on the toolbar", click on the Extensions button menu.
    5. Select Always show.
    I hope this helps, too!
    From OLDSKOOL VENNING
    2024-06-04T12:57:16+00:00
    Hi Ivo, welcome to Microsoft Answers. I know how to turn off ad blockers. Did you download an ad blocker extension? If so, remove it in these steps:
    1. Click on Extensions in the toolbar.
    2. Go to that extension's menu and click on Remove from Microsoft Edge.
    • A dialog box will appear asking you if you want to remove the extension from Microsoft Edge.
    • Do not click on the Report abuse checkbox.
    • Click Remove.
    I hope this helps!
    From OLDSKOOL VENNING (An Microsoft User)
