Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-21T18:04:58+00:00
    Same problem. This fixed worked. Thanks
    2025-05-21T18:55:21+00:00
    Fantastic! It worked. Thanks Larry.
    2025-05-21T19:32:48+00:00
    Hey Kimberly, I just wanted to see if you did both the settings and the CMD lines or did you just change the settings?
    2025-05-21T20:30:30+00:00
    This worked!
    2025-05-21T21:44:25+00:00
    Same here. My wife's computer is doing it too.
