Edge will not close - any help please?
2025-05-17T09:07:34+00:00
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
Microsoft Edge | Other | Windows 10
    2025-05-21T15:40:57+00:00
    My thread is getting a bit long - is there a way to close it now? Its obvious there is an issue and there is enough info on here now. As the original poster do I do something to close it?
    2025-05-21T15:45:35+00:00
    how do I unfollow replies??
    Above the comment section, click Subscribe > Unsubscribe
    2025-05-21T16:05:38+00:00
    This worked for me.
    After making these changes I had to close out through the task manager. I then re-opened the browser and was able to close the window via the "x".
    2025-05-21T17:26:31+00:00
    So doing all of the powershell cmds and doing this list of settings has returned my MS Edge back to normal, Thanks for all the work.
    2025-05-21T17:27:01+00:00
