Other issues or features related to Microsoft Edge on Windows 10
Ok - This morning I opened Edge (w10) and when I clicked the X to close, it would not close. I tried to minimise and click close, still would not work. I can only close it via task manager or rebooting. Nothing has chnaged since last night, so no idea why it has happened. Is there a simple answer as in apps both uninstall and modify are grayed out.
The PC is mine, not a work one and is W10.
Keith
PS - Just tried with my w10 laptop, am able to close edge as normal. So have no idea why the desktop is playing up. Is there a solution?
None of the supposed "fixes" have worked for me. Edge used to work just fine, so clearly it's a Microsoft problem and they need to fix it.
i have the same question
Sadly, this did not work for me. I still have the problem.
Nop, it does not close at all. I have to use Task Manager
I had the same issue, I saw the original post this morning and ran some tests before posting. This seems to be working for me:
1 Click three dots at top right
2 Click settings
3 Click System and performance
4 Click System
Turn off the following:
I have not determined which is the issue but turning each back on one at a time and testing can be done by you. But this did work for me.
Larry
IT Professional
Thank you SO MUCH!
This worked for me in my situation.
Respect!
