How to remove frame around Add a Text box on pdf in Edge?
2025-02-10T18:49:39+00:00
The most recent update to Microsoft Edge (133.0.3065.51), now puts a frame/box around text when adding text to a pdf. How to remove this? It doesn't appear to be an accessibility setting.
Microsoft Edge | Read PDFs | Windows 11
2025-02-11T08:27:00+00:00
Hi KBRWU
Welcome to Microsoft Community.
Based on your description, I understand that you have found that Microsoft Edge (133.0.3065.51) adds a frame around the text when adding text to a PDF, and I understand how you feel!
Please allow me to explain that I am just a support person on the forums and not a member of the Microsoft Edge development team.
Thank you very much for your feedback my friend, I see that there are very many users with the same problem.
So I immediately tested it via my laptop and reproduced the issue without any problem.
But the good news is that I found a solution to this problem.
Here is a distribution step I wrote.
  1. Open the Edge browser.
  2. Type "edge://flags" in the search bar at the top.
  3. When the page opens, type in and search for PDF.
  4. Set “New PDF Viewer” to “Enabled”.
  5. Check whether the problem still exists.
Because in my test environment, I enabled this setting and the problem disappeared.
As shown:
Assuming that there are users who have enabled the “New PDF Viewer” feature in their settings, we can also try to disable it to see if the problem still exists.
I sincerely hope that the above information and programs will help you! Please feel free to contact me if you have any problems or still can't solve them. (Photos related to the question would be great!).
I look forward to hearing back from you.
Best Regards
Arthur Sheng | Microsoft Community Support Specialist
900+ people found this answer helpful.
100 additional answers
    2025-02-14T19:17:05+00:00
    THANK YOU!!! not only was the box there, but it covered up some of the text making it hard to read. better to not have the box, and why someone would think it was a good idea.... well they are dumb. Don't try to improve something that you don't use....otherwise you would have noticed it isn't right. OR maybe even then they would not have noticed??? either way, it removed the box!!!! Now you can understand what is typed on the page. :)
    2025-02-14T19:53:15+00:00
    Hi Arthur.
    Thanks for the tip. Disabling the New PDF option does not get rid of the box around added text. Enabling the New PDF option does get rid of the box around added text, but it creates a couple new problems with text that is already entered into the document into text fields built into the document (not text added to the document via the Add Text function).
    With New PDF option enabled
    Firstly, if there is a text field built into the document (such as the PDFs I am using), the text boxes added by the Add Text function cannot be selected unless the Add Text button is clicked if the text box is encapsulated by the text field built into the document. Also, in the text field built into the document, the original font changes to Arial when this text is selected - this makes entering text and formatting paragraphs difficult. Enabling the new PDF option can also affect the existing paragraph formatting in text fields built into the document from before the option is enabled.
    Is there a way to ONLY remove the text box borders without affecting the rest of the document?
    2025-02-14T20:03:56+00:00
    Brilliant; have been trying to get rid of the box for ages...
    2025-02-14T23:43:20+00:00
    It works thank you
