Opening and reading PDF files in Microsoft Edge on Windows 11
The most recent update to Microsoft Edge (133.0.3065.51), now puts a frame/box around text when adding text to a pdf. How to remove this? It doesn't appear to be an accessibility setting.
Hi KBRWU
Welcome to Microsoft Community.
Based on your description, I understand that you have found that Microsoft Edge (133.0.3065.51) adds a frame around the text when adding text to a PDF, and I understand how you feel!
Please allow me to explain that I am just a support person on the forums and not a member of the Microsoft Edge development team.
Thank you very much for your feedback my friend, I see that there are very many users with the same problem.
So I immediately tested it via my laptop and reproduced the issue without any problem.
But the good news is that I found a solution to this problem.
Here is a distribution step I wrote.
Because in my test environment, I enabled this setting and the problem disappeared.
As shown:
Assuming that there are users who have enabled the “New PDF Viewer” feature in their settings, we can also try to disable it to see if the problem still exists.
I sincerely hope that the above information and programs will help you! Please feel free to contact me if you have any problems or still can't solve them. (Photos related to the question would be great!).
I look forward to hearing back from you.
Best Regards
Arthur Sheng | Microsoft Community Support Specialist
Thank you! This has helped tremendously. Even though Edge is not my preferred browser, it is a better medium when filling out most forms. So glad that frame around the text disappeared.
THIS WORKED AND IT SAVED ME! THANK YOU!
Thank you, worked for me!
I have been trying to figure this out for weeks. Thank you for explaining it and making it easy to reset. I appreciate this so much!
