Opening and reading PDF files in Microsoft Edge on Windows 11
The most recent update to Microsoft Edge (133.0.3065.51), now puts a frame/box around text when adding text to a pdf. How to remove this? It doesn't appear to be an accessibility setting.
Hi KBRWU
Welcome to Microsoft Community.
Based on your description, I understand that you have found that Microsoft Edge (133.0.3065.51) adds a frame around the text when adding text to a PDF, and I understand how you feel!
Please allow me to explain that I am just a support person on the forums and not a member of the Microsoft Edge development team.
Thank you very much for your feedback my friend, I see that there are very many users with the same problem.
So I immediately tested it via my laptop and reproduced the issue without any problem.
But the good news is that I found a solution to this problem.
Here is a distribution step I wrote.
Because in my test environment, I enabled this setting and the problem disappeared.
As shown:
Assuming that there are users who have enabled the “New PDF Viewer” feature in their settings, we can also try to disable it to see if the problem still exists.
I sincerely hope that the above information and programs will help you! Please feel free to contact me if you have any problems or still can't solve them. (Photos related to the question would be great!).
I look forward to hearing back from you.
Best Regards
Arthur Sheng | Microsoft Community Support Specialist
Thank you! Very helpful!
THANK YOU, THANK YOU, THANK YOU!
Hi, I am unable to complete the same steps as "New PDF Viewer" doesn't appear on my Experiments page. Could I please have your assistance?
This is how my page looks like: Screenshot
Thank you!
Your edge browser installation is showing "Update" in the top right hand corner.
You need to click that first to update your edge browser install to the latest version.
After browser restarts i expected the edge://flags view with search "pdf" filter applied will display the "new pdf viewer" option.
