How to remove frame around Add a Text box on pdf in Edge?
2025-02-10T18:49:39+00:00
The most recent update to Microsoft Edge (133.0.3065.51), now puts a frame/box around text when adding text to a pdf. How to remove this? It doesn't appear to be an accessibility setting.
Microsoft Edge | Read PDFs | Windows 11
2025-02-11T08:27:00+00:00
Hi KBRWU
Welcome to Microsoft Community.
Based on your description, I understand that you have found that Microsoft Edge (133.0.3065.51) adds a frame around the text when adding text to a PDF, and I understand how you feel!
Please allow me to explain that I am just a support person on the forums and not a member of the Microsoft Edge development team.
Thank you very much for your feedback my friend, I see that there are very many users with the same problem.
So I immediately tested it via my laptop and reproduced the issue without any problem.
But the good news is that I found a solution to this problem.
Here is a distribution step I wrote.
  1. Open the Edge browser.
  2. Type "edge://flags" in the search bar at the top.
  3. When the page opens, type in and search for PDF.
  4. Set “New PDF Viewer” to “Enabled”.
  5. Check whether the problem still exists.
Because in my test environment, I enabled this setting and the problem disappeared.
As shown:
Assuming that there are users who have enabled the “New PDF Viewer” feature in their settings, we can also try to disable it to see if the problem still exists.
I sincerely hope that the above information and programs will help you! Please feel free to contact me if you have any problems or still can't solve them. (Photos related to the question would be great!).
I look forward to hearing back from you.
Best Regards
Arthur Sheng | Microsoft Community Support Specialist
900+ people found this answer helpful.
100 additional answers
    2025-02-20T21:40:10+00:00
    I have tried to disable and enable but cannot get rid of the border. Almost became a victim of a scammer while searching the internet for tech support. Very frustrating day.
    2025-02-20T21:46:53+00:00
    Make sure you click the "restart" button on the bottom of the screen to apply the new settings or it won't work. Got me twice until i noticed it! (:
    2025-02-20T21:53:51+00:00
    Leslie, Yes. Did that too. Restart the computer and cleared the cache. Thx
  4. Deleted
