Opening and reading PDF files in Microsoft Edge on Windows 11
The most recent update to Microsoft Edge (133.0.3065.51), now puts a frame/box around text when adding text to a pdf. How to remove this? It doesn't appear to be an accessibility setting.
Hi KBRWU
Welcome to Microsoft Community.
Based on your description, I understand that you have found that Microsoft Edge (133.0.3065.51) adds a frame around the text when adding text to a PDF, and I understand how you feel!
Please allow me to explain that I am just a support person on the forums and not a member of the Microsoft Edge development team.
Thank you very much for your feedback my friend, I see that there are very many users with the same problem.
So I immediately tested it via my laptop and reproduced the issue without any problem.
But the good news is that I found a solution to this problem.
Here is a distribution step I wrote.
Because in my test environment, I enabled this setting and the problem disappeared.
As shown:
Assuming that there are users who have enabled the “New PDF Viewer” feature in their settings, we can also try to disable it to see if the problem still exists.
I sincerely hope that the above information and programs will help you! Please feel free to contact me if you have any problems or still can't solve them. (Photos related to the question would be great!).
I look forward to hearing back from you.
Best Regards
Arthur Sheng | Microsoft Community Support Specialist
Hi Arthur,
This doesn't work for me.
Any other solutions?
I tried and it's working now. Thanks
Worked on my Windows 11 computer, but the New PDF viewer option doesn’t seem to be available on Edge for MacOS. Any solution for Mac users?
Thanks so much, this has worked!
