Opening and reading PDF files in Microsoft Edge on Windows 11
I have a problem with printing from the latest version of Microsoft Edge. When I select some text on the browser and choose Print → 'Save As Pdf', the download starts but never finishes. How can I fix this? Is this a common issue for all the users of the latest version of Edge?
I have tried restating the PC, Resetting the browser, stopping all the extension etc. to fix it. but it doesn't work? Should I switch to Chrome?
As per t6he response from Mitchell I reported the feedback and would encourage others to
That didn't work with the files from "Save as PDF" that got me off on this tangent. In fact the first thing I tried was to change the file extension to PDF. No Joy!
Could you try if this extension would work as a temporary solution?
https://microsoftedge.microsoft.com/addons/detail/save-as-pdf/mlgefgipndlgdfjfgnjfheigkagjieea
@mcp59
I have found a fix/workaround in copying and renaming the CRDOWNLOAD file from xxx.crdownload to xxx.pdf. This seems to work and keeps it searchable.
@BoeFamily8874
Save as PDF
In file explorer I see "Unconfirmed xxxxx.crdownload" copy and rename to "filename.pdf".
The renamed file will open as an OCR pdf file.then Cancel and delete download file in EDGE browser.
File explorer will still show "Unconfirmed xxx.crdownload" in Recent history - the file does not exist - it may be "removed from Recent".What a pain.
Windows 11 23H2, EDGE Version 120.0.2210.61 (Official build) (64-bit)
That is interesting. When I tried to do that a couple of days ago Windows did not let me rename the file. Closing Edge so that the file was freed up also deleted the file.
What worked for me was to make a copy of the xxx.crdownload file and I was able to rename the copy.
I guess it is a pain in the **** until Microsoft fixes the problem.
