Adjust "something" in Edge/Android for better reading of PDF files?
2024-03-17T21:09:00+00:00
When I read PDF files using Edge on my Android phone, is there a way to adjust "something" so the text "fits" on the screen and is easily readable w/o the need to swipe, which for lengthly documents is painful.
MS Word has a feature called "Mobile View" that allows PDF files to "fit" and be very readable on the phone's screen.
Microsoft Edge | Read PDFs | MacOS
    2024-03-19T10:06:44+00:00
    Hi DaveLPG47,
    Welcome to Microsoft Community.
    Unfortunately, Microsoft Edge for mobile has limited functionality and adjustable configurations and does not include PDF-related configuration items.
    Optimization of the product's functionality relies on customer feedback and investigation by the product team.
    For product-specific feature suggestions, you can submit your ideas in the feedback option provided by the app.
    If I misunderstand your situation, feel free to correct me and share the information.
    Best Regards,
    Kyo - MSFT | Microsoft Community Technical Support
