Managing tabs, address bar, and search settings in Edge on Windows 10
Hello
That started suddenly
Activating the "collection" tab on Edge produce the following error in
"This content is blocked. Contact the site owner to fix the issue."
And on mobile (Edge for Android), "collection" buttons give that error:
"It's not you, it's us
Bing isn't available right now, but everything should be back to normal very soon."
This occurs only with my profile synced to my Microsoft account. Other profiles using other account work find on both devices
I would be Ok to completely erase my synced profile (but I don't know how to do that) but *not* my Microsoft account.
Hi everyone,
The engineers are working to restore Collection functionality as soon as possible. We apologize for any inconvenience this may have caused and appreciate your patience and understanding.
Update: We have fixed the problem. We appreciate your feedback and cooperation.
Your data should be OK it can be found here :
C:\Users*your user name*\AppData\Local\Microsoft\Edge\User Data\Default\Collections
Data I spent hours collecting is missing from my local file. It is useless for what I had hoped to do before encountering the current problem.
That the collections user interface when logged out differs from when logged in makes me suspicious (the "..." menu is different, e.g.). I suspect my local file contains none of the changes I made since 112.0.1722.58. I am currently on Version 114.0.1823.43 (Official build) (64-bit).
Thanks for the heads up
You are not alone. I'm having same issue.
I cleared my cache, disabled VPN and restarted Edge.... issue remains.
That the user interface when logged out differs from when logged in makes me suspicious (the "..." menu is different, e.g.). I suspect my local file contains none of the changes I made since 112.0.1722.58. I am currently on Version 114.0.1823.43 (Official build) (64-bit).
This would not be the first time that a new build has wiped out the Collections.
Instead of worrying about things like making the corners of the apps round (who knew they were not!) why doesn't Microsoft ensure that the basic program works, before bombarding us with new Builds. Makes me think that there is a bonus for the team that puts out the most builds every week!
