Managing tabs, address bar, and search settings in Edge on Windows 10
Hello
That started suddenly
Activating the "collection" tab on Edge produce the following error in
"This content is blocked. Contact the site owner to fix the issue."
And on mobile (Edge for Android), "collection" buttons give that error:
"It's not you, it's us
Bing isn't available right now, but everything should be back to normal very soon."
This occurs only with my profile synced to my Microsoft account. Other profiles using other account work find on both devices
I would be Ok to completely erase my synced profile (but I don't know how to do that) but *not* my Microsoft account.
Hi everyone,
The engineers are working to restore Collection functionality as soon as possible. We apologize for any inconvenience this may have caused and appreciate your patience and understanding.
Update: We have fixed the problem. We appreciate your feedback and cooperation.
Please contact Microsoft technical support to resolve your issue with Collections. Tech support will restore your ability to use this feature.
Issue on my side too.
On Default profile the access to edge://collections is stopped. Apparently needs a rework on the React module for the Collections app.
New profiles working without issue.
Running as Admin doesn't fix it.
Every time I just rename the files, they reappear and error comes back.
Waiting for a flash update on that section to solve it than.
Windows fresh install also same when syncing to my profile.
The issue was resolved by Microsoft some time ago.
I suggest you update your Edge browser and try again.
