Suddenly unable to use "collections" on Edge
2023-06-09T10:45:10+00:00
Hello
That started suddenly
Activating the "collection" tab on Edge produce the following error in
"This content is blocked. Contact the site owner to fix the issue."
And on mobile (Edge for Android), "collection" buttons give that error:
"It's not you, it's us
Bing isn't available right now, but everything should be back to normal very soon."
This occurs only with my profile synced to my Microsoft account. Other profiles using other account work find on both devices
I would be Ok to completely erase my synced profile (but I don't know how to do that) but *not* my Microsoft account.
Microsoft Edge | Tabs, address bar, and search | Windows 10
2023-06-09T17:00:08+00:00
Hi everyone,
The engineers are working to restore Collection functionality as soon as possible. We apologize for any inconvenience this may have caused and appreciate your patience and understanding.
Update: We have fixed the problem. We appreciate your feedback and cooperation.
91 additional answers
    2023-06-10T17:15:20+00:00
    Mine are in process of "updating" ... Hoping they all will be there!
    We are updating your collections! Please keep Collections open until the update is finished.
    Finished as I was typing. Several are still Synching though...
    Looks like some of mine collection folders are empty :(
    For the most part they all appear to be there.
    Need to explore exporting this list. A few articles out there on how to do it supposedly,.
    Good luck to all!
    2023-06-10T18:50:20+00:00
    They are copied to another place, then I rename the ones in the Collections folder, then copy the backup ones over. Finally reboot then open Edge and test.
    2023-06-10T21:23:28+00:00
    Thanks, R. DennisSteed and Smiler1958. I'll try that when I finish with my current Windows hair-tearing problem. My Win 11 machine can see and access the 2 Win 10 machines on my network, but they cannot access it, but can access each other---which means that it's a Win 11 problem. I am about to uninstall the last update that was a security update, because things were just fine earlier today! What's interesting is that the update does not appear in "Uninstall an update", but there is a restore point prior to it being installed.
    Is there any way to completely turn off Windows updates? I'd like to turn them off, and then turn them on after some time has passed, and the bugs have been fixed.
    2023-06-21T13:18:05+00:00
    Collections still not working on my laptop. how can i resolve this?
