Getting ERR_NETWORK_CHANGED 5 times per minute
2024-01-08T05:29:39+00:00
Your connection was interrupted
A network change was detected.
ERR_NETWORK_CHANGED
macOS 14.2.1 (23C71)
Microsoft Edge Version 120.0.2210.121 (Official build) (arm64)
Microsoft Edge | Browser crashes or stops working | Android
    2024-01-09T09:20:08+00:00
    Could you also try disable Edge secure network following these steps:
    https://www.elevenforum.com/t/enable-or-disable...
    Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products). Thoroughly research any product advertised on the site before you decide to download and install it.
    2024-01-09T08:30:28+00:00
    No. I also have reset to the default settings and disabled all extensions, but still getting this issue.
    2024-01-08T08:03:44+00:00
    Hi, I'm Elise, a fellow user like yourself and I'd be happy to help with your issue.
    Are you using any internet security software or a VPN connection? This can cause issue like this sometimes.
    Kind Regards,
    Elise
