[SOLVED] Can't login on Edge anymore! (Sync issue)
2024-03-20T18:33:08+00:00
PLEASE READ UPDATES (4) BELOW - ISSUE SOLVED
Original Message:
Already hit restore on windows' applications and restarted my pc, but every time I open Microsoft Edge now, on the top right corner it says my account is not logged in. And when I try to do it, the pop-up window says it's loading and then just turns to all white.
Anyone can help me please? Don't want to lose my favourites, passwords and workspaces ;_;
UPDATE 21 March:
  1. already deleted all cookies
  2. already confirmed if it was an issue with the Wi-Fi
  3. already hit «repair» twice on the program
  4. already tried to add a new account (didn't work cause the issue with the popup to login is the same)
  5. already disabled all extensions and tried to login again after that
  6. my account is not blocked - in fact I can login on Microsoft with it on my phone and website (otherwise I wouldn't be able to post this question). The issue is only with logging in on the Edge browser;
  7. already deleted and reinstalled Edge.
And yes, I restarted my pc every time I tried something. What else can I do? I need to access my Edge Workspaces!
UPDATE 24th March:
  • multiple people have replied with the same issue and it seems to be some kind of bug that happened after last update KB5035853.
  • still no workaround or any feedback.
  • this issue was also posted on techcommunity and no answers to this date.
  • I am using Windows 10 Home version 22H2, with Edge version: 123.0.2420.53 (64 bits) [also trying on Edge Beta version: 123.0.2420.53]
UPDATE 25TH MARCH
  • Still waiting on confirmation from the Tech Community but it seems like I ran out of workarounds.
  • and yeah, no 3rd party issues as well. All checked and updated.
  • So if you are experiencing the same, please report the issue with as much as detail as possible on Help > Send (Alt + Shift + I) after following all workarounds as well;
  • If in the meanwhile anyone finds a solution, please share it. I would greatly appreciate it as my job is depending on it. Thank you!
UPDATE 10 APRIL:
Finally got a hold on https://support.microsoft.com/, initiated a live chat with support, and they had to install Install Quick Assist (Install Quick Assist - Microsoft Support) and they had to enter my PC and check what was wrong. They had no idea what was happening at the time (this all happened a few weeks ago - sorry for the late reply ut I had a lot of work delayed due to this error) and reinstalled Windows = issue solved.
The following day however, windows asked me to update again and the issue returned ahahahaha but I removed it, and then the following system updates didn't carry that sign in issue anymore.
Thank you all for your help and support during these VERY STRESSFUL DAYS! Hope the issue got solved for everyone!
Microsoft Edge | Profile, sync, and sign in | Windows 10
    2024-03-26T15:48:58+00:00
    It's true. Later I had the same issue, with Explorer and other features like Start Menu and Task Bar not working. Enabling the updates again and installing them indeed fixed everything (at least for now)!
    2024-03-27T08:21:30+00:00
    Not so lucky here, unfortunately :(
    BR
    Torbjørn
    2024-03-27T09:08:05+00:00
    Have you tried these steps in this order?
    • do a recovery to before the last main system update (System>Recovery)
    • pause the automatic updates
    • uninstall ALL the latest updates
    • restart the PC
    (- this is when explorer and stuff may glitch)
    • enable the updates again and let it install everything again
    This worked for some users...
    2024-03-27T10:53:48+00:00
    Unfortunately, no. I tried removing the updates, but to no avail. Then reinstalled them, still no joy.
    Best regards,
    Paulo
    2024-03-27T14:23:16+00:00
    Hi, I had the exact same problem (but on Windows 11).
    This was what worked for me: How to fix blank white screen preventing signing in - Microsoft Community
    TL;DR - Seems that people affected use a non English-us Windows language (I have it in Portuguese as well), switching to English-US and then try to login should work. You're safe to switch back to Portuguese/Your previous language aftwards.
    Good luck
