Managing profiles and sync in Microsoft Edge on Windows 10
PLEASE READ UPDATES (4) BELOW - ISSUE SOLVED
Original Message:
Already hit restore on windows' applications and restarted my pc, but every time I open Microsoft Edge now, on the top right corner it says my account is not logged in. And when I try to do it, the pop-up window says it's loading and then just turns to all white.
Anyone can help me please? Don't want to lose my favourites, passwords and workspaces ;_;
UPDATE 21 March:
And yes, I restarted my pc every time I tried something. What else can I do? I need to access my Edge Workspaces!
UPDATE 24th March:
UPDATE 25TH MARCH
UPDATE 10 APRIL:
Finally got a hold on https://support.microsoft.com/, initiated a live chat with support, and they had to install Install Quick Assist (Install Quick Assist - Microsoft Support) and they had to enter my PC and check what was wrong. They had no idea what was happening at the time (this all happened a few weeks ago - sorry for the late reply ut I had a lot of work delayed due to this error) and reinstalled Windows = issue solved.
The following day however, windows asked me to update again and the issue returned ahahahaha but I removed it, and then the following system updates didn't carry that sign in issue anymore.
Thank you all for your help and support during these VERY STRESSFUL DAYS! Hope the issue got solved for everyone!
i have the same problem
using windows 10 and latest update
any follow up or work-around on this issue?
Just uninstall KB5035853!
Hi. My Windows account has stopped logging in to edge, office outlook, windows store, etc... I get a white window when I log in and nothing happens! I've reinstalled windows and it's still the same. Any solutions?
The original poster in this thread has reported elsewhere that McAfee antivirus is running on the problem machine. Do any other affected users also have third-party antivirus or other 'security' software running? Which?
Interference from this type of software is a very common cause of problems in Windows.
I have same issue, cant sign in to any Microsoft products after KB5035853 install. (Windows account, office 365, Edge) Only get the blank / white login window with no tekst. W11 pro and W11 Home is the same. Im in Norway. Seriously Microsoft, stop fooling people to do reinstalls and other stupid thing. You should know better.
