it was ok this morning, what changed, Edge is blocking my access to Ebay. will not allow me to print very important shipping labels
2023-07-28T22:07:00+00:00
www.ebay.com is blocked
This page has been blocked by Microsoft Edge ERR_BLOCKED_BY_CLIENT
Microsoft Edge | Tabs, address bar, and search | Previous Windows versions
    2023-07-28T23:18:21+00:00
    Hi, Jerry,
    Sorry to hear you're experiencing this issue.
    Usually, this problem is caused by cached information on the browser, clearing the browser cache should fix this problem.
    1-Open the browser then press Ctrl+Shift+Delete
    2-Click on the advanced tab and change the time range to 'All'
    3-Check all options then click on the Clear button.
    4-When finished, relaunch the browser and check if the problem was fixed
    Alert: This procedure will delete all cached files including saved passwords and autofill information.
    Other possible causes for this error are:
    -Third-party antivirus, if you have one try to disable it temporarily and then try to access eBay
    -Third-party extensions. Try to disable all extensions and then try to access eBay again
    1-Open the Microsoft Edge
    2-Type: edge://extensions/ in the address bar and press enter
    3-Disable all extensions
    4-Relaunch the browser and try to access eBay again
    I hope this information helps. If you have any questions, please let me know and I'll be glad to assist you further.
