Edge Microsoft Start
2024-06-17T11:04:06+00:00
After the last update, you just screwed the Edge Microsoft start page: it doesn't load and clicking on anything, from 'Iniciar sessão' to settings, etc doesn't work, not to mention that the bookmarks that should be showing under 'Procurar na web' are gone. It's a total disaster!!! Thanks for forcing me to return to Chrome.
EDITED to add that I'm on a Mac; and here's a video for you to see this issue:
https://app.screencastify.com/v3/watch/aJYUgWU8Rblwuh4S1OoN
the page never loads, it's just an infinite blinking. Unbelievable what an update can do!!
Microsoft Edge | Open the browser | Android
  1. SD - IA 179.6K Reputation points Independent Advisor
    2024-06-19T02:24:51+00:00
    Thank you.
    Does Edge Beta work correctly?
    https://aka.ms/EdgeInsider
    2024-07-01T08:12:27+00:00
    Issue is now solved (nothing done on my end), and everyting's working properly, although for some unknown reason the language has now turned to to Spanish...
