Edge Microsoft Start
2024-06-17T11:04:06+00:00
After the last update, you just screwed the Edge Microsoft start page: it doesn't load and clicking on anything, from 'Iniciar sessão' to settings, etc doesn't work, not to mention that the bookmarks that should be showing under 'Procurar na web' are gone. It's a total disaster!!! Thanks for forcing me to return to Chrome.
EDITED to add that I'm on a Mac; and here's a video for you to see this issue:
https://app.screencastify.com/v3/watch/aJYUgWU8Rblwuh4S1OoN
the page never loads, it's just an infinite blinking. Unbelievable what an update can do!!
Microsoft Edge | Open the browser | Android
  1. SD - IA 179.6K Reputation points Independent Advisor
    2024-06-17T14:14:57+00:00
    I'm Sumit, here to answer your query at the Microsoft Community.
    Nothing changed. This is just a connectivity issue.
    Can you see if changing the DNS helps?
    1. Press Windows+R keys on the keyboard, or Right-click Start on the Taskbar and choose Run.
    Type ncpa.cpl
    Press Enter.
    1. Right-click your device and select Properties.
    2. Double click IPv4 options to open IPv4 properties.
    4.Select the ""Use the following DNS servers"" radio box, and enter the following in the addresses.
    1.1.1.1
    1.1.2.2
    1. Click OK and OK again.
    Restart your computer.
    Keep us posted and Good luck!
    2024-06-17T15:04:43+00:00
    Thank you, but I'm on a Mac... You saying "This is just a connectivity issue." made me laugh, because this is not a connectivity issue, this is screwing big time.
  3. SD - IA 179.6K Reputation points Independent Advisor
    2024-06-17T15:45:34+00:00
    My apologies for missing this that this is a mac.
    I stand by my analysis as per previous reports. The New tab page from MSN is having troubles connecting hence it shows a generic page.
    Via
    https://answers.microsoft.com/en-us/microsofted...
    The new tab page shown in that thread is the default one you'd normally see if there was no Internet connection or some other reason why the MSN server couldn't be reached. Can you open https://ntp.msn.com/edge/ntp?
    2024-06-18T08:25:24+00:00
    I can open it and it's the same thing: never actually loads, infinite blinking.
    2024-06-18T08:30:05+00:00
    And one other thing: I'm no longer entitled to watching video content in full screen without having to endure the right sidebar... Guys, pleaaaaaase!!!!
