Opening and reading PDF files in Microsoft Edge on macOS
Under all the android systems, such as Samsung, Xiaomi... the Edge app cannot highlight the PDFs texts and save these highlights as usual as in Windows. Any solutions? Thanks.
Good day Deng, thanks for your question. I am glad to be able to provide assistance to you today. You can check and test if this is also happening even on the version which you can download via the link below and If you will continue to experience the issue even after trying the above then you can also send a feedback to the team that is working on Edge and hopefully a fix/patch will be applied soon on the next update and you can provide a feedback from the browser itself by tapping on the 3 dots > Help and feedback or via the link below as well.
https://play.google.com/store/apps/details?id=c...
https://techcommunity.microsoft.com/t5/discussi...
Regards,
Paul R.
Thanks, Paul, I tried the beta version, but still doesn't work, guess it's function missing.
In this case, you will need to provide the feedback to the Edge team as instructed above on my initial response so that they check on this and hopefully this will be fixed on the next update.
