How can I eliminate Temu ads from my Edge browser?
2023-12-11T01:41:26+00:00
I keep getting ads from Temu on Edge Browser. How can I eliminate Temu Since I know it is a scam Company from China selling knock off products that are of no real value in my opinion.
Thank you,
Dave
Microsoft Edge | Other | Windows 11
    2024-01-04T02:14:57+00:00
    Hello David Weiler1 ,
    I am very sorry that you are experiencing such distress. I completely understand how you feel.
    If you are still unable to block these ads through the options I have provided, they may be intrusive ads. I can help you by contacting our Edge MSN team.
    You can send feedback to the MSN team directly through Microsoft Edge.
    Simply press ALT-SHIFT-I (note the letter i, not the number 1) to navigate to the Send Feedback option.
    Or in Edge, click the three horizontal dots icon in the upper right corner to expand the menu, click "Help and Feedback" near the bottom, and then Send Feedback.The Edge MSN team will see your feedback.
    You can refer to this step-by-step guide: General advice for MSN-related concerns - Microsoft Community
    Best Regards ,
    Morning | Microsoft Technical Support Community
    2024-01-07T19:59:07+00:00
    Yep. Disgusted with all the Temu ads. I'm going back to Google
    2024-01-08T18:47:24+00:00
    After 4 months of trying I believe the ads have stopped on my MSN news feed that I use everyday. They still appear in other places throughout my browsing. Now they come up when I visit other sights, or scroll through other MSN traffic. So just keep posting to MSN and they will remove it,
    2024-01-09T13:59:49+00:00
    Thanks for your reply. I have attempted to stop Temu add and it is getting better.
    2024-01-14T22:39:26+00:00
    I totally agree with the others. This ad is a scam and I have tried everything you have suggested and nothing works. I may have to quit Edge and switch because it is all over my home page.
