cursor lagging only on edge
2024-08-18T17:44:00+00:00
my cursor lags but only on edge it works n9rmally if i move it slowly but any normal amount of speed makes it start lagging/
Microsoft Edge | Speed and responsiveness | Windows 10
    2024-08-19T07:33:08+00:00
    Hi, Miranda Bolan
    Welcome to the Microsoft community.
    Based on your description, this issue only occurs in Edge, so it might be caused by something specific to Edge. Here are some steps you can try:
    1. Toggle Hardware Acceleration: Try switching the hardware acceleration on and off in Edge to see if the issue persists in both scenarios. You can find this setting under Settings > System and performance > Use hardware acceleration when available. edge://settings/system
    2. Create a New Edge Profile: Create a new Edge profile to test if the issue occurs there as well. This can help rule out any extensions causing the problem. edge://settings/profiles
    3. Version Compatibility: If the issue persists, it might be due to compatibility problems with the current version of Edge. Try using a different version of Edge (such as the Canary or Beta version) to see if the problem still exists. Become a Microsoft Edge Insider | Microsoft Edge
    Additionally, I recommend submitting this issue directly to the developers using Alt+Shift+I.
    Best regards
    Tommy Jin | Microsoft Community Support Specialist
