Edge unwantedly adding border around text
2025-02-07T15:21:20+00:00
When I add text to a pdf in edge, suddenly it it adding a box around the text. It doesn't show up until I hit enter. It's super annoying and I'm sure I did something to turn it on but I can't figure out how to turn it off.
Microsoft Edge | Read PDFs | Windows 11
2025-02-11T09:28:47+00:00
  1. Open the Edge browser.
  2. Type "edge://flags" in the search bar at the top.
  3. When the page opens, type in and search for PDF.
  4. Set “New PDF Viewer” to “Enabled”.
  5. Check whether the problem still exists.
This worked for me.
***Moderator note: Source***
600+ people found this answer helpful.
2025-02-08T15:32:27+00:00
I'm seeing the same issue on various computers. The version of Edge is the same (133.0.3065.51) on affected and unaffected systems.
Here is what it looks like: Broken
Here is what it should look like: Working
Resetting Edge does not resolve the issue.
90 additional answers
    2025-02-19T07:12:04+00:00
    Dear Laura g5
    You can try to change the PDF Viewer, which can effectively solve the problem you are currently encountering.
    Open edge.
    Type edge://flags in the address bar and press Enter.
    Search keyword 'New PDF Viewer'
    Change Default to Enabled
    Looking forward to receiving your feedback.
    Best Regards,
    Martin | Microsoft Community Support Specialist
    I followed the directions, but the frames / boarders still persist :-( .
    2025-02-20T04:49:43+00:00
    That worked for me as well. Took a little bit to find the Settings page, as it opened in a new tab.
  3. Deleted
