Edge unwantedly adding border around text
2025-02-07T15:21:20+00:00
When I add text to a pdf in edge, suddenly it it adding a box around the text. It doesn't show up until I hit enter. It's super annoying and I'm sure I did something to turn it on but I can't figure out how to turn it off.
Microsoft Edge | Read PDFs | Windows 11
2025-02-11T09:28:47+00:00
  1. Open the Edge browser.
  2. Type "edge://flags" in the search bar at the top.
  3. When the page opens, type in and search for PDF.
  4. Set “New PDF Viewer” to “Enabled”.
  5. Check whether the problem still exists.
This worked for me.
***Moderator note: Source***
600+ people found this answer helpful.
2025-02-08T15:32:27+00:00
I'm seeing the same issue on various computers. The version of Edge is the same (133.0.3065.51) on affected and unaffected systems.
Here is what it looks like: Broken
Here is what it should look like: Working
Resetting Edge does not resolve the issue.
90 additional answers
    2025-02-12T13:56:42+00:00
    This worked for me! Thank you
    2025-02-12T14:30:39+00:00
    THANK YOU SO MUCH!!
    2025-02-12T14:34:47+00:00
    This solved the first problem, however when opening a prefilled pdf form, the prefilled text is all deleted, creating a second problem. Please add this bug to the priority list to get updated. THANKS!
