Improving performance and responsiveness of Edge on Windows 10
On Windows 10, regardless of what keyboard I use, in Microsoft Edge, I found myself needing to press CTRL+C multiple times or using the context menu to copy text on a webpage. When I disable the "Show mini menu when selecting text", I no longer have this problem. How can this be fixed without having to change settings?
Hello Nicolas,
I am Jaspreet Singh.
Is this happening on any particular website or all of them?
And do you know if this started happening after a recent edge update?
It's the same regardless of the website, ctrl+c copies just fine in other browsers is just edge for some reason you either have to ctrl+c multiple times of right-click copy.
