Launching Microsoft Edge on Windows 11
Xbox One, Microsoft Edge won't open. Was working yesterday, now it doesn't.
Microsoft support is of no help, if they don't disconnect your call then, they want you to do everything you already have done before even contacting them: I already did a soft reboot, hard reboot, clear local games, check updates (cant update Microsoft Edge), keep apps/games updated, etc...
Okay, I've had the same issue as everyone else, have done everything including totally erasing every hint of edge from my system including the registry, and a hundred other things. WHY does this work? Because it worked!
it worked thanks for the solution
It worked for me!
that WORKED. THANK YOU!
Works like a dream, thx.
