Launching Microsoft Edge on Windows 11
Xbox One, Microsoft Edge won't open. Was working yesterday, now it doesn't.
Microsoft support is of no help, if they don't disconnect your call then, they want you to do everything you already have done before even contacting them: I already did a soft reboot, hard reboot, clear local games, check updates (cant update Microsoft Edge), keep apps/games updated, etc...
Okay, I've had the same issue as everyone else, have done everything including totally erasing every hint of edge from my system including the registry, and a hundred other things. WHY does this work? Because it worked!
Hi, good day! I'm Jerico T., I understand that you're having some issues right now, I'll do my best to help you with your concern.
Kindly try to make sure that Windows is up to date then perform the steps below.
If the steps above did not work, please run a System File Checker to check if there are any corrupted system files that's causing the issue. Click the link below for the steps.
https://support.microsoft.com/en-us/windows/usi...
Please do let me know if you need any further assistance.
Hope this help. Have a good day.
Thank you,
Jerico T.
I'm having the same issue as of today. No udpates were installed or anything, just suddenly it crashed and is not oppening.
I restarted
I tried reparing
I completely uninstalled and redownloaded it the installed it again
I installed it in different ways, through a download file and the through the app store
I ran system health check DISM.exe /Online /Cleanup-image /Restorehealth
nothing is working. and when I check the reliability report it's showing me nothing about edge.
note: I noticed also an update that shows under apps, installed on 24 of May. Unable to modify or uninstall the update. Also the update stays there under apps even after removing edge. Maybe has something to do with this problem? Update: 1.3.187.39
Yes we have the same problem on one of our laptops, was working first thing this morningcthen stopped and unable to open now
need help to get this working ASAP
Hi. I have totally same bug problem.
I created post few days back too.
Please guys from Microsoft help me and other asap. Thank you.
