Right clicking on Edge, menu appears on different screen, same happens for context menu
2025-01-21T09:30:02+00:00
I have three screens and using Windows 10. When I right click on the right part of my main screen, the context menu appears on the third screen. The same happens on the left side of my second screen. This also happens for all sub menu items. For example if I click the three dots and go to "Tools" which has a sub-menu, the sub-menu appears on the third screen. This is extremely frustrating. I noticed it after the latest update.
I have tried all the basics including restarting my PC etc. to no avail.
Microsoft Edge | Other | Windows 10
  1. Deleted
    2025-01-31T09:45:54+00:00
    Mine has started working correctly today. There is an update in the browser but I haven't restarted the browser for it to take effect so not sure what has changed.
    2025-01-31T14:27:34+00:00
    I also had a browser update, but to fix the problem I had to reboot the PC, restarting Edge wasn't enough.
    Anyway, it's working again and that's the most important thing.
    2025-02-01T02:09:56+00:00
    I have found doing a Ctrl-Shift-Win-B to restart the graphics drivers will minimise the problem for a while.
    Not a perfect solution but it is quick.
    2025-02-01T12:07:14+00:00
    Laptop screen set to 125%, with two external monitors.
    Using Edge on the MIDDLE monitor, with the window full screen, or placed to the right side of the screen, the "Settings" menu will appear on the wrong monitor -- it'll show on the far right monitor.
    Same goes for window popups from plugins...
    I installed latest chrome update, and I tried resetting the video card... problem persists.
