Github Not working, Microsoft Edge Linux
2023-05-01T14:44:58+00:00
I am using Microsoft edge on debian linux, however when I go to github, I get error code 4.
I am using Microsoft Edge 114.0.1807.1 dev, and I have done minimal configuration(only changing apearance),
I have signed in using outlook.
EDIT: it looks like only the default github page is not working as I am able to view repositories and other pages on github, I am
even able to sign in, but the create an account page does not work
Microsoft Edge | Browser crashes or stops working | iOS
2023-05-01T15:21:37+00:00
Hello Sergio, welcome to the Microsoft community, I'll be happy to help you today;
I understand that you are unable to access GitHub on Edge using Linux;
It appears this issue is common with Edge on Linux, the development team is currently investigating the issue;
The temporary solution is to downgrade to an earlier version of Edge until this issue is fixed in the current version of Edge;
Hope this helps, see you soon!
1 additional answer
    2023-05-01T23:24:58+00:00
    I see, thank you, ill downgrade to an earlier version.
