Can Microsoft edge be installed on school chromebook without linux
2023-12-12T19:26:04+00:00
I have a school Chromebook and i am going nuts about why they don't let you use Microsoft edge or other browsers.
Does anyone have information?
Many thanks
* Moved from Community Center
Microsoft Edge | Install and update | MacOS
Brian Tillman [Outlook MVP 2007-2019] 25,920 Reputation points
2023-12-12T20:51:57+00:00
This forum is dedicated to providing feedback on this Microsoft Community web site. You should have asked in the Edge forum.
I'd like to get Edge on my Chromebook as well and it will install on my Android phone but it won't on my Chromebook. The Play Store prevents it. I'm not sure why. There may be workarounds you could employ but the Chromebook is not yours and I daresay the school would frown on you trying to modify their equipment unsanctioned.
2 additional answers
    2024-02-23T16:24:29+00:00
    aw darn it! I was so enthusiastic of trying to get it on my Chromebook that's blocked
    2024-03-21T18:08:10+00:00
    if you want to have Edge as your browser go to
    https://www.microsoft.com/en-us/edge?ep=313&form=MA13M0&es=40 This will let you install Microsoft
    and also by the way you can just install Windows 10 since the iso is supported
    go to https://www.microsoft.com/en-us/software-download/windows10ISO if your device doesn't let you install any of these sites please go to https://www.microsoft.com/help
