Installing or updating Microsoft Edge on macOS
Hi there, so about two months ago the Microsoft Edge Beta app for android in the Google play store stopped being compatible with my android 7 and even worse now the Edge app (non beta) is also no longer compatible with my android 7 phone. I've left feedback, I've emailed the developer but with no success. So I'm wondering if anyone knows how I could get this resolved. I believe it's just a matter of the developer updating the min sdk version, but naturally I could be mistaken. Any help would be appreciated. I was really enjoying Edge and had basically incorporated it as my main browser in place of Firefox which I had used for years. It would be a shame to no longer be able to use Edge on Android. Thanks in advance for your time and your help, it is appreciated. Cheers!
Hello Robin Mc,
Welcome to the Microsoft Community!
I'm sorry to hear that you're experiencing Edge app compatibility issues with Android, and I understand that this must be causing you a lot of frustration.
In order to better understand your issue, I'd like to invite you to share more details with me:
If you haven't updated edge, updating to the latest version may solve some known issues. Please refer to: Update to the new Microsoft Edge - Microsoft Support
If these actions don't solve your problem, please reply to me with the questions above, and this will determine our next step in the right direction! Looking forward to your reply.
Best Regards ,
Morning | Microsoft Technical Support Community
Hi there,
Thank you so much for getting back to me, I really appreciate it and in reading my question back I realize that I wasn't clear at all about what the specific issue was and apologize. So an extra big thank you for still trying to help.
The issue I'm having is related to updating the app in the Google Play Store. In the Play Store, when I go to update either Edge or Edge Beta the option to update is not available and instead in red text it says "This app is no longer compatible with your device. Contact the developers for more info."
Both the Edge and Edge Beta apps still work, but I'm not able to update them to the newest version.
I've read online that I should clear the Play Store Cache and app caches and have done so. I've also updated my phone. I haven't uninstalled and reinstalled the apps for fear that I won't be able to reinstall them at all due to the compatibility issue. I understand from reading online that it's probably related to my phone only being android 7 and that in the latest updates to the apps the developer(s) probably set the minSdkVersion to something higher than Android 7. I understand Android 7 is an older version and I've had this issue with other apps but they always clear themselves up, either on their own or with a quick email to the developer.
Thanks again for getting back to me. I really do appreciate it.
Hello Robin Mc,
Thank you very much for coming back to us!
Based on the additional information you have provided I have learned more about the problem you are experiencing.
I noticed that you've tried a number of ways to resolve the issue but the problem persists and I understand that you're getting the message "This application is no longer compatible with your device" and I can direct you to the right way to contact the edge developers:
Click on Microsoft Edge Insider - Microsoft Community Hub **** and share this issue description here, there are edge developers in this community who can provide you possible solutions.
Please mark yes for this reply to help improve the user pointing experience. Thank you for your cooperation and I hope you can resolve the issue successfully!
Best Regards ,
