Troubleshooting website display or functionality issues in Edge on macOS
I believe Edge Android does not truly installs PWA, instead it creates a shortcut on the home screen. If I install PWA from Chrome, the app is added to the App drawer and also shows up in Settings > Apps list. This is not the case when installing via Edge. It only shows up on the home screen and there is a edge logo at the bottom right corner of the app logo.
This is not a site specific issue, I have created multiple PWAs that install perfectly on other platforms and browsers except Edge. I even tried the demo from Edge and it also behaves in the same way.
Ah got it. It was under "All Menu".
Alright Vipul and hopefully this will be fixed anytime soon.
Hello friends, how are you? I'm having exactly the same problem. Is there any solution please?
