Edge Android does not truly install PWA
2024-04-05T04:21:06+00:00
I believe Edge Android does not truly installs PWA, instead it creates a shortcut on the home screen. If I install PWA from Chrome, the app is added to the App drawer and also shows up in Settings > Apps list. This is not the case when installing via Edge. It only shows up on the home screen and there is a edge logo at the bottom right corner of the app logo.
This is not a site specific issue, I have created multiple PWAs that install perfectly on other platforms and browsers except Edge. I even tried the demo from Edge and it also behaves in the same way.
Microsoft Edge | Website issues | MacOS
    2024-04-07T03:12:07+00:00
    Ah got it. It was under "All Menu".
  2. paulr0511 48,640 Reputation points Independent Advisor
    2024-04-07T03:23:42+00:00
    Alright Vipul and hopefully this will be fixed anytime soon.
    2024-11-06T01:46:14+00:00
    Hello friends, how are you? I'm having exactly the same problem. Is there any solution please?
