Zoom Setting for PDF Viewer in Edge
2023-11-17T08:36:01+00:00
Hi new user,
As per this thred
Zoom Setting for PDF Viewer in Edge - Microsoft Community
Its been over 2 years and i wonder has this been answered?
Thanks for your help.
Microsoft Edge | Read PDFs | Windows 10
    2023-11-17T09:30:10+00:00
    Hi, there.
    I'm Jen. I'm an independent advisor and would happily help you figure this out.
    Unfortunately, it's still the same. You will need to adjust zoom to your preferred setting using ctrl then scroll up or down if it shows differently in Microsoft Edge PDF viewer. You can also submit feedback using the link below or press Alt+Shift+I in Microsoft Edge.
    https://feedbackportal.microsoft.com/feedback/f...
    Kind regards.
    2023-11-18T05:44:42+00:00
    Haven't tried it before. But no worries, let's wait for the others who might be able to share a workaround.
    Kind regards.
    2023-11-17T09:44:59+00:00
    Hi, thanks for your reply :)
    Is there anything we could put in the target location of the edge shortcut as a command for pdf opening, I know its possible with other *.exe files for other commands ?
    Simon
