Launching Microsoft Edge on Android devices
I have read the instructions on here and tried a few things but it still doesn't work
The way i tried:
but its not work
Thanks for help
Hi, I'm Elise, a fellow user like yourself and I'd be happy to help with your issue.
Does it work if you don't force quit? As far as I understand about this feature it simply kills the process for Edge, so it won't give it a chance to run these cleanup routines on shut down.
Kind Regards,
Elise
And this problem just started happening 2-3 days ago, before that it was normal.
If it was working prior to this with the same settings it suggest something may have changed with the way this is handled in Edge. It might be worth uninstalling and reinstalling the latest version from the Edge website
