Since a few days ago my homepage is not showing in Edge
2023-06-28T12:53:17+00:00
Since a few days ago my homepage is not showing in Edge.
I'm using macOS Catalina, does anyone know what's going on?
Microsoft Edge | Open the browser | Android
    2023-06-28T13:30:35+00:00
    Hello RobertJ21,my name is Luiz Cruz independent consultant and I'm here to help you;
    I understand that your new tab page is not showing in Edge;
    If you try to access other web pages does it work normally?
    Initially I recommend that you try the following;
    Make sure Edge is up to date;
    Open Edge and go to Settings;
    Click on About Microsoft Edge in the menu on the left of the screen;
    If there is an update, it will be done;
    Try resetting the Edge settings;
    Click on Reset settings in the menu on the left of the screen;
    Click on Restore settings to their default values;
    Click Reset;
    Restart Edge and check if the home page is open;
    Hope this helps, see you soon!
