Edge is sharing Chrome site logins. How do I prevent this?
2022-01-27T17:33:41+00:00
I have a site where I have two accounts. I used to be able to have one of them logged in with Edge and one with Chrome, then by running the right browser, I could be logged in with the right profile.
Now, Edge seems to have started copying the login across from Chrome, i.e. I can't separate them. Logging in on Chrome logs in with the same credentials on Edge which isn't what I want.
How do I turn this off so that each browser can log in with different credentials and stay logged in with those credentials? I've found lots of stuff about syncing my MS account across devices, but this is on one single device and two browsers that I want to be completely unrelated.
Thanks.
Microsoft Edge | Profile, sync, and sign in | Windows 10
    2023-09-08T15:08:31+00:00
    Hey this is not impossible this is happening . Just in my case . I Just installed win 10 and used edge to download chrome . after that i started using chrome. But one i opened edge then found that google account is already logged in in edge . which i have done in chrome . I saw that edge has also have all my bookmark everything .
    Then i thought to signout my account from edge . But when i have done so my chrome browser session also got logged out .
    This might because both are chromium and both are using same appdata folder to save their configuration file in backend . But i think this need to be addressed .
    2023-12-04T22:28:35+00:00
    I too have ran across this seems that some facebook messenger ap caused it all
    They wanted to merge all my facebook acounts into one then say they cant delete it its permanent.
