Edge is sharing Chrome site logins. How do I prevent this?
2022-01-27T17:33:41+00:00
I have a site where I have two accounts. I used to be able to have one of them logged in with Edge and one with Chrome, then by running the right browser, I could be logged in with the right profile.
Now, Edge seems to have started copying the login across from Chrome, i.e. I can't separate them. Logging in on Chrome logs in with the same credentials on Edge which isn't what I want.
How do I turn this off so that each browser can log in with different credentials and stay logged in with those credentials? I've found lots of stuff about syncing my MS account across devices, but this is on one single device and two browsers that I want to be completely unrelated.
Thanks.
Microsoft Edge | Profile, sync, and sign in | Windows 10
    2023-06-22T13:21:53+00:00
    Amazing. It worked! Great job, and thanks!
    2023-07-24T14:28:57+00:00
    Awesome!! this works better. Thank you so much.
    2023-08-14T22:22:43+00:00
    I'm going through the same thing. It's frustrating. I use Edge as my primary and Chrome as secondary browser. All the accounts I log into on Chrome get transferred to Edge shortly after, and the accounts that are in Edge get logged out and replaced with the same ones from Chrome. It doesn't make sense for them to do this. It's a security flaw because it's logging into the accounts without even asking for my permission.
    2023-08-24T00:51:37+00:00
    I just tried this. Hoping it works. I am using Youtube using one acc on Chrome and then another different acc on Edge. A lot of open tabs on both browsers. Even after I completely removed Chrome Youtube Acc from Edge, it still showed up when I opened it again. Thanks a lot. This should be marked as the right answer to this question.
    2023-09-01T14:50:04+00:00
    Geez dude, you're a freakin' saint! Thank ya much! This was drivin' me nuts!
