Managing profiles and sync in Microsoft Edge on Windows 10
I have a site where I have two accounts. I used to be able to have one of them logged in with Edge and one with Chrome, then by running the right browser, I could be logged in with the right profile.
Now, Edge seems to have started copying the login across from Chrome, i.e. I can't separate them. Logging in on Chrome logs in with the same credentials on Edge which isn't what I want.
How do I turn this off so that each browser can log in with different credentials and stay logged in with those credentials? I've found lots of stuff about syncing my MS account across devices, but this is on one single device and two browsers that I want to be completely unrelated.
Thanks.
I turned those off and it still does it. Edge still influences Chrome.
It doesn't work for me.
Just want to add that I'm observing the same so-called "bizarre and impossible" behavior. I log into gmail on Chrome and Edge will log in to that same account. This is after I've already cleared browsing data from Edge.
It would be helpful if you could give a few more details about what's happening.
It sounds as if your Edge settings need reviewing. I can't help with what goes on in Chrome, I'm afraid.
Last, I'd ask why you feel it necessary to use more than one browser to access your Gmail accounts. Is it just to keep the mail accounts separate from each other? If so, Edge has ways of doing just that.
This didn't work for me! And it's SO frustrating!
I have a new computer - windows 11 - and the linking of accounts between Edge and Chrome is driving me crazy!
