Netflix error on Edge Chromium
2020-10-31T14:51:45+00:00
I am discouraged that this problem has not been fixed after several months. I am a long-time a Netflix subscriber. Since I upgraded a few months ago to the new Edge Chromium browser, Netflix always returns error code D7353-5101. Refreshing the browser screen always allows Netflix to play normally. Even so, it is a damned nuisance. Netflix support says that Netflix does not support the Edge chromium browser, and  recommends using Google Chrome or Firefox browsers. It would seem to me that not supporting a widely used service such as Netflix would be a very big negative that Microsoft would want to fix. Yet... months go by and no fix.
Before anyone asks, I do not use third party AV. Windows has been updated since the problem appeared, and is up-to-date.
Microsoft Edge | Website issues | Windows 10
2021-06-01T16:56:42+00:00
Update - the 5C release is KB5003214. This has an additional fix for the signing issue that caused the symptom investigated here.
Arvind
61 additional answers
    2021-01-20T01:58:46+00:00
    Edge browser has updated again. This time to Version 87.0.664.75 and still the promised fix to the Netflix error message has not happened.
    2021-01-20T02:48:07+00:00
    Man, forget the browser.
    Netflix's windows desktop application will give you more features and easier to navigate through it.
    Instead of using the netflix website, just download the netflix app for windows from here :
    Get Netflix - Microsoft Store en-IN
    After using this you'll never go back to the site again
    2021-01-20T14:09:07+00:00
    I don't want to install another program. Netflix works just fine on Firefox. I can't believe that  Microsoft doesn't care about customers leaving Edge to watch Netflix on another browser.
    2021-01-25T02:05:39+00:00
    Hi, sorry to hear about this issue. Can you please share the Windows version number (Start -> winver) as well as Edge version number (from edge://version) where you're currently experiencing this symptom?
    Confirm that you have the latest Windows updates?
    Are you also seeing the symptom go away on browser refresh?
    Arvind
