How to remove MSN from microsoft edge start page ?
Reported
2021-05-23T13:19:48+00:00
I have been trying to get rid of the MSN by the ways I found but non is working I would really like some help.
* Moved from MSN
Microsoft Edge | Open the browser | Windows 10
Reported
2022-03-31T17:04:15+00:00
Like you, I had no desire to see the news feed upon startup OR when I open a new tab.
First, navigate to Edge's settings using the three dots on the upper right hand side of the window
Next, navigate to "Start, home, and new tabs"
In the "Start, home, and new tabs" section, I personally have it set to a couple sites/tools I use regularly for work, but you can set it to "Open the new tab page" which I'll get to below.
Edge handles new tabs separately and you are required to "personalize" the new tab layout. To do this, while still on the "Start, home, and new tabs" settings page, scroll down to "New tab page" then click "Customize"
Now, on the top right, click the cog icon and select "Custom"
Here, you can remove all "features" and content
Now, your new tabs should open up to something that resembles this, and if you set your startup page to "Open the new tab page" it should show this upon startup as well. :)
Hope this helps everyone!
52 additional answers
  1. Reported
    2021-05-24T12:50:49+00:00
    Thank you for writing to Microsoft Community Forums.
    In order to get clarity and to assist you accordingly, please reply with the answers to the questions below:
    • What is the Version and Build of Windows 10 installed on the PC? (Type winver in Windows search/Run command)
    • What is the version of Edge installed on the PC? (Open Edge > click on (…) dots from top right corner > click on Settings > Click on About Microsoft edge from the left pane).
    • When you say “the ways I found but non is working” what are the ways you tried?
    Let us perform these steps.
    Choose what to set on Startup of Edge.
    Open Edge > click on (…) dots from top right corner > click on Settings > click On Startup from the left pane > Select Open a Specific page or pages > Add the URL as shown below
    Regards,
    Aditya Roy
    Microsoft Community – Moderator
    2021-05-24T13:09:55+00:00
    Thank you for the help.
    The Version and Build of Windows 10 installed on the PC: version 20H2 (OS Build 19042.985)
    The version of Edge installed on the PC: Version 90.0.818.66 (Official build) (64-bit)
    I followed the steps and added the URL.
    2021-05-25T02:44:54+00:00
    Thank you for your response.
    We would like to know if the suggestion provided in my post resolved the issue.
    Regards,
    Aditya Roy
    2021-05-25T07:16:04+00:00
    Thank you for being patient with me
    The problem is still not solved
