how to stop edge from being managed by an organization
2023-04-19T22:49:23+00:00
how to stop edge from being managed by an organization I don't have? Just recently starting doing this...
Microsoft Edge | Other | Windows 11
    2024-03-31T11:23:25+00:00
    I have the same issue but my computer said it could not find this and i ran it on cmd in administartor
    2024-03-31T13:29:51+00:00
    Thanks for your time and effort but
    no luck.
    went through all scenarios but nothing
    2024-05-08T19:17:50+00:00
    Here's what mine says. And no, resetting my settings didn't work.
    2024-05-08T19:22:49+00:00
    T
    This should say everything you need to know about whether or not it resolves the issue.
  5. _AW_ 69,496 Reputation points Volunteer Moderator
    2024-05-09T00:05:53+00:00
    What you entered is not a valid command so of course it didn't work.
    Run Powershell as administrator then copy and paste in the command below and press enter;
    reg delete HKLM\SOFTWARE\Policies\Microsoft\Edge /f;reg delete HKCU\SOFTWARE\Policies\Microsoft\Edge /f;
    If you need further assistance, start a new thread.
